thinkgeo.mapsuite.webedition.layeroverlay
ThinkGeo.MapSuite.WebEdition.LayerOverlay
Represents an Overlay that contains layers.
    • ThinkGeo.MapSuite.WebEdition.Overlay
      • ThinkGeo.MapSuite.WebEdition.LayerOverlay
LayerOverlay()
  • Initialize an instance of the LayerOverlay class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#LayerOverlay.28.29
LayerOverlay(String)
  • Initialize an instance of the LayerOverlay class with the overlay identifier specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#LayerOverlay.28String.29
  • id
    • Description:The identifier string used to retrieve the overlay for collection.
LayerOverlay(String,Boolean,TileType)
  • Initialize an instance of the LayerOverlay class with the overlay identifier, IsBaseOverlay boolean value and the value indicating whether to use tiling.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#LayerOverlay.28String.2C_Boolean.2C_TileType.29
  • id
  • isBaseOverlay
    • Description:A boolean value that indicates whether this overlay is a base overlay.
  • tileType
    • Type:TileType
    • Description:The TileType that indicates whether this overlay uses tiling.
SetBaseEpsgProjection(String)
  • Sets the EPSG projection of the LayerOverlay when it is a base overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#SetBaseEpsgProjection.28String.29
  • epsgProjection
    • Description:A string that represents the projection of the LayerOverlay.
GetBaseEpsgProjection()
  • Returns an EPSG string that indicates the projection of the LayerOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#GetBaseEpsgProjection.28.29
  • Description:An EPSG string that indicates the projection of the LayerOverlay.
GetBoundingBox()
  • Gets the smallest extent that includes all of the features of all layers in the LayerOverlay.
  • If you have several layers, with one justified up and to the right and another justified down and to the left, this method will combine all of the current extents to make one composite extent.
  • Description:The smallest extent that includes all of the features of all layers in the LayerOverlay.
Draw(GeoCanvas,Object,RectangleShape,GeographyUnit)
  • Draw all of the layers to the image object using the parameters specified.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Draw.28GeoCanvas.2C_Object.2C_RectangleShape.2C_GeographyUnit.29
  • canvas
    • Type:GeoCanvas
    • Description:The GeoCanvas object that the layers will draw on.
  • nativeImage
    • Description:The image object to which all of the layers will be drawn. Usually it is a bitmap.
  • canvasExtent
    • Description:The extent in which the features of the layers will be drawn.
  • mapUnit
    • Description:The geographic unit that the map will use to draw.
Redraw()
  • Redraw this overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Redraw.28.29
GenerateCacheImages(ZoomLevel,RectangleShape,GeographyUnit)
  • Generates images to the server cache by zoomLevel.
  • This method will generate images to the server cache if you enable the ServerCache on this LayerOverlay. You can use this method to fill your server cache to enhance the performance of your web site.
  • zoomLevel
    • Type:ZoomLevel
    • Description:The zoomlevel at which the images will be generated.
  • cacheExtent
    • Description:The extent of the region for which the cached images will be generated.
GenerateCacheImages(Double,RectangleShape,GeographyUnit)
  • Generates the images to the server cache by scale.
  • scale
    • Description:The scale that is used to calculate the coordinates of the images.
  • cacheExtent
    • Description:The extent of the region for which the cache images will be generated.
ToJson()
  • Returns a JSON string which contains the information for creating an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ToJson.28.29
  • Description:A JSON string which is used to create an overlay at the client side.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#GetType.28.29
DrawCore(GeoCanvas,Object,RectangleShape,GeographyUnit)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#DrawCore.28GeoCanvas.2C_Object.2C_RectangleShape.2C_GeographyUnit.29
  • canvas
    • Type:GeoCanvas
  • nativeImage
  • canvasExtent
  • mapUnit
3xM=(Page)
  • page
    • Type:Page
  • Registers a Javascript library URL string to the client HTML page.
  • The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
  • Raises the Tick event of the MarkerOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#OnTick.28EventArgs.29
  • e
    • Type:EventArgs
    • Description:An System.EventArgs object that contains the event data.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#MemberwiseClone.28.29
TileWidth
Gets or sets the width of each tile if the layer is in MultipleTile mode.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileWidth
TileHeight
Gets or sets the height of each tile if the layer is in MultipleTile mode.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileHeight
TransitionEffect
Gets or sets the transition effect to use when the map is zoomed.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TransitionEffect
TransitionEffectDelayInMilliseconds
TileType
Gets or sets whether or not the LayerOverlay uses tiling.
TileMargin
Gets or sets the number of extra rows and colums of tiles on each side that will surround the minimum grid tiles to cover the map. Used only when in MultipleTile mode.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#TileMargin
ServerCache
Gets or sets the server cache in the overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ServerCache
ClientCache
Gets or sets the ClientCache object that contains the configuration for the browser cache of this overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ClientCache
WebImageFormat
Gets or sets the format of the image that is sent to the web browser.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#WebImageFormat
JpegQuality
Gets or sets the quality of the JPEG image that is sent to the web browser. Valid values are between 1 - 100, inclusive.
The <strong>JpegQuality</strong> property determines the quality of the JPEG image that is sent to the browser if the WebImageFormat is Jpeg. Setting this property to a lower value will reduce the image filesize. The value must be between 1 - 100. The default is 100.
IsMultiThreadDisabled
Gets or sets whether the multi-thread is disabled or not.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsMultiThreadDisabled
Layers
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsVisible
WrapDateline
Gets or sets a value that indicates whether the overlay wraps at the date line.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#WrapDateline
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Name
Opacity
Gets or sets the opacity level of the overlay.
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#IsBaseOverlay
Id
Gets the identifier for the overlay to be found.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Id
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#AutoRefreshInterval
  • Type:TimeSpan
Attribution
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#Attribution
OverlayType
Gets a string that indicates the overlay type.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#OverlayType
ExtraParameter
Gets or sets extra parameters for current overlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#ExtraParameter
Projection
Gets or sets projection of current overlay for requesting images.
HasTickEvent
Indicates whether the overlay supports tick event.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#HasTickEvent
3hM=
Tick Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.LayerOverlay#OnTick.28EventArgs.29
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.layeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
