thinkgeo.mapsuite.webedition.clientcache
ThinkGeo.MapSuite.WebEdition.ClientCache
This class controls how the map images are cached by the browser.
    • ThinkGeo.MapSuite.WebEdition.ClientCache
ClientCache()
  • Initializes a new instance of the ClientCache class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#ClientCache.28.29
ClientCache(TimeSpan)
  • Initializes a new instance of the ClientCache class with the specified expiration time.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#ClientCache.28TimeSpan.29
  • duration
    • Type:TimeSpan
    • Description:The amount of the time that the cached images are to remain in the browser cache.
ClientCache(TimeSpan,String)
  • Initializes a new instance of the ClientCache class with the specified expiration time and cacheId string.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#ClientCache.28TimeSpan.2C_String.29
  • duration
    • Type:TimeSpan
  • cacheId
    • Description:A string that the browser uses to retrieve a cached image.
ToJson()
  • Returns a JSON string containing the CacheId that will be part of the request string.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#ToJson.28.29
  • Description:A JSON string that contains the CacheId.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ClientCache#MemberwiseClone.28.29
Duration
Gets or sets the expiration time of the images in the browser cache.
The <strong>Duration</strong> indicates the length of time that images will remain in the browser cache before expiring. The default value is 7 day.
  • Type:TimeSpan
CacheId
Gets or sets a string that enables the browser to cache images, and which is also part of the key for the browser to distinguish between each cached image.
Setting the <strong>CacheId</strong> will enable the browser to cache the map images. The <strong>CacheId</strong> string will also be appended to the URL of the image. The browser uses the URL as the key to retrieve a cached image; thus, you can make the browser cache different images by setting the <strong>CacheId</strong> to different values. For example, you can set a different CacheId for requests with different parameters and the browser will cache the different images for those requests.
thinkgeo.mapsuite.webedition.clientcache.txt · Last modified: 2017/03/16 21:59 (external edit)
