thinkgeo.mapsuite.mvcedition.valuemarkerstylesetting
ThinkGeo.MapSuite.MvcEdition.ValueMarkerStyleSetting
A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
ValueMarkerStyleSetting(ValueMarkerStyle)
  • Initializes a new instance of the ValueMarkerStyleSetting class.
ColumnName(String)
  • Set columnName for Element property and retun the ValueMarkerStyleSetting
  • columnName
    • Description:A columnName for Element property
ValueItems(MarkerValueItem)
  • Set markerValueItem for Element property and retun the ValueMarkerStyleSetting
  • markerValueItem
Element
thinkgeo.mapsuite.mvcedition.valuemarkerstylesetting.txt · Last modified: 2017/03/16 21:59 (external edit)
