thinkgeo.mapsuite.androidedition.adornmentoverlay
ThinkGeo.MapSuite.AndroidEdition.AdornmentOverlay
    • ThinkGeo.MapSuite.AndroidEdition.Overlay
      • ThinkGeo.MapSuite.AndroidEdition.AdornmentOverlay
AdornmentOverlay()
  • Initializes a new instance of the class.
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(RectangleShape,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
GetBoundingBox()
Initialize(MapArguments)
Refresh()
Refresh(RectangleShape)
Draw(MapArguments,OverlayRefreshType)
PostTransform(TransformArguments,MapArguments)
Close()
Open()
Dispose()
InitializeCore(MapArguments)
  • This method initializes overlay object.
  • When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
DrawCore(MapArguments,OverlayRefreshType)
  • This method draws the overlay with the provided extent in world coordinate.
  • mapArguments
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
Dispose(Boolean)
  • Releases unmanaged and - optionally - managed resources.
  • disposing
    • Description:true to release both managed and unmanaged resources; false to release only unmanaged resources.
GetBoundingBoxCore()
RefreshCore()
RefreshCore(RectangleShape)
PostTransformCore(TransformArguments,MapArguments)
CloseCore()
OpenCore()
  • exception
    • Type:Exception
  • ex
    • Type:Exception
OnDrawingException(DrawingExceptionOverlayEventArgs)
OnDrawnException(DrawnExceptionOverlayEventArgs)
ShowLogo
  • Gets or sets a value indicating whether [show logo].
IsEmpty
  • This property indicates whether this overlay is empty or not.
  • This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
Layers
  • This property gets a collection of the AdornmentLayers that are added to the AdornmentOverlay.
  • Type:TimeSpan
DrawingExceptionMode
IsVisible
Attribution
OverlayView
DrawingQuality
Opacity
MapArguments
CanRefreshRegion
DrawingException
Event Arguments:DrawingExceptionOverlayEventArgs
DrawnException
Event Arguments:DrawnExceptionOverlayEventArgs
thinkgeo.mapsuite.androidedition.adornmentoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
