thinkgeo.mapsuite.androidedition.transformarguments
ThinkGeo.MapSuite.AndroidEdition.TransformArguments
Class TransformArguments.
    • ThinkGeo.MapSuite.AndroidEdition.TransformArguments
TransformArguments()
  • Initializes a new instance of the class.
TransformArguments(Single,Single,Single,RectangleShape,Single,Single)
  • x
    • Type:Single
    • Description:The x.
  • y
    • Type:Single
    • Description:The y.
  • scale
    • Type:Single
    • Description:The scale.
  • processingExtent
  • centerX
    • Type:Single
    • Description:The center x.
  • centerY
    • Type:Single
    • Description:The center y.
PostScale(Single,Single,Single)
  • Posts the scale.
  • scale
    • Type:Single
  • centerX
    • Type:Single
  • centerY
    • Type:Single
PostTranslate(Single,Single)
  • Posts the translate.
  • offsetX
    • Type:Single
    • Description:The offset x.
  • offsetY
    • Type:Single
    • Description:The offset y.
Reset()
  • Resets this instance.
Set(TransformArguments)
  • Sets the specified matrix.
CenterX
  • Gets or sets the center x.
  • Type:Single
CenterY
  • Gets or sets the center y.
  • Type:Single
ProcessingExtent
  • Gets or sets the processing extent.
Scale
  • Gets or sets the scale.
  • Type:Single
X
  • Gets or sets the x.
  • Type:Single
Y
  • Gets or sets the y.
  • Type:Single
Rotation
  • Gets or sets the rotation.
  • Type:Single
thinkgeo.mapsuite.androidedition.transformarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
