thinkgeo.mapsuite.mvcedition.googleoverlaysetting
ThinkGeo.MapSuite.MvcEdition.GoogleOverlaySetting
A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
GoogleOverlaySetting(GoogleOverlay)
  • Initializes a new instance of the GoogleOverlaySetting class.
GoogleMapType(GoogleMapType)
  • Set googleMapType for Element property and retun the GoogleOverlaySetting
  • googleMapType
    • Description:A googleMapType for Element property
JavaScriptLibraryUri(Uri)
  • Set libraryUri for Element property and retun the GoogleOverlaySetting
  • libraryUri
    • Type:Uri
    • Description:A libraryUri for Element property
GoogleStreetView(GoogleStreetView)
TrafficEnabled(Boolean)
  • enabled
TiltEnabled(Boolean)
  • enabled
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.googleoverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
