thinkgeo.mapsuite.portablecore.unmanagedproj4projection
ThinkGeo.MapSuite.Core.UnmanagedProj4Projection
    • ThinkGeo.MapSuite.Core.Projection
      • ThinkGeo.MapSuite.Core.UnmanagedProj4Projection
UnmanagedProj4Projection()
This is the default constructor for this class.
This conctructor pass nothing. After this cconstructor , you should set the InternalProjectionParametersString property and ExternalProjectionParametersString property before open to use.
UnmanagedProj4Projection(String,String)
This constructor allows you to pass in Proj4 text parameters for the to and from projection. The parameters typically look like “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs” You should use this constructor when you know the parameters. If you know the SRID directly you can use the other constructor that takes the SRID.
  • internalProjectionParametersString
    • Description:This parameter is the projection parameters describing the data.
  • externalProjectionParametersString
    • Description:This parameter is the projection parameters describing the projection you want to go to.
UnmanagedProj4Projection(Int32,Int32)
This constructor allows you to pass in Proj4 srid parameters for the to and from projection. The parameters typically look like 4320 stands for “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs” and 4604 stands for “ +proj=longlat +ellps=clrk80 +towgs84=174,359,365,0,0,0,0 +no_defs”. You should use this constructor when you know the parameters. If you know the SRID directly you can use the other constructor that takes the SRID.
  • internalEpsgSrid
    • Description:This parameter is the projection srid parameter describing the data.
  • externalEpsgSrid
    • Description:This parameter is the projection srid parameter describing the projection you want to go to.
UnmanagedProj4Projection(String,Int32)
  • externalEpsgSrid
UnmanagedProj4Projection(Int32,String)
  • internalEpsgSrid
Dispose()
This is the dispose method for the class.
This dispose releases the handles of the Proj4 library. You should normally use Close instead of dispose unless you really want to never use this instance again. Normally when a layer is finished drawing it will call the Close of the projection class. This allows the object to be serialize but used again in the future. You should only use the Dispose method when you do not want to use this class again.
  • Description:None
CloneDeep()
Open()
ConvertToExternalProjection(GeoImage,RectangleShape)
ConvertToExternalProjection(GeoImage,RectangleShape,RectangleShape)
Close()
ConvertToExternalProjection(Double,Double)
  • x
  • y
ConvertToExternalProjection(BaseShape)
ConvertToExternalProjection(Feature)
  • feature
ConvertToExternalProjection(IEnumerable<Vertex>)
  • vertices
    • Type:IEnumerable<Vertex>
ConvertToInternalProjection(Double,Double)
  • x
  • y
ConvertToInternalProjection(Feature)
  • feature
ConvertToInternalProjection(IEnumerable<Vertex>)
  • vertices
ConvertToInternalProjection(RectangleShape)
GetInternalGeographyUnit()
GetExternalGeographyUnit()
GetEpsgParametersString(Int32)
This method is a static API to get a projection text from EPSG(European Petroleum Survey Group).
More information about it can reference to EPSG.rtf in the documentation.
  • Description:The project text corresponding to the srid.
  • srid
    • Description:The target Srid infromation to get the projection text from.
GetEsriParametersString(Int32)
This method is a static API to get a projection text from ERSI.
More information about it can reference to ERSI.rtf in the documentation.
  • srid
GetGoogleMapParametersString()
This method is a static API to get a projection used by GoogleMap.
  • Description:A text for a projection used by GoogleMap , it should like this “+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs”
GetWgs84ParametersString()
This method is a static API to get a projection text from World projections.
GetLatLongParametersString()
GetDecimalDegreesParametersString()
GetLocalUtmZoneParametersString(Double,Double)
  • longitude
  • latitude
GetLocalUtmZoneParametersString(Feature,String)
  • feature
  • proj4ProjectionParameters
GetLocalUtmZoneParametersString(Feature,Int32)
  • feature
  • srid
GetLocalUtmZoneParametersString(BaseShape,String)
GetLocalUtmZoneParametersString(BaseShape,Int32)
  • srid
GetLocalUtmZoneNumber(Double,Double)
  • latitude
  • longitude
GetLocalUtmZoneNumber(Feature,String)
  • feature
GetLocalUtmZoneNumber(Feature,Int32)
  • feature
  • srid
GetLocalUtmZoneNumber(BaseShape,String)
GetLocalUtmZoneNumber(BaseShape,Int32)
  • srid
GetGeographyUnitFromPrj(String)
  • prjString
GetGeographyUnitFromProj4(String)
  • proj4String
ConvertEpsgToPrj(Int32)
This method is a static API to get a Prj string by Epsg number
  • srid
    • Description:Epsg number that reprents this projection
ConvertProj4ToPrj(String)
  • proj4String
ConvertPrjToProj4(String)
  • prjString
OpenCore()
This method open the projection and gets it ready to use.
As this is the core version of the Open method it is intended to be overridden in inherited version of the class. When overriding you will be responsible for getting the projection classes state ready for doing projections. In this override we call the Proj4 methods get it ready for projection.
  • Description:None
CloseCore()
This method closes the projection and gets it ready to serialization if necessary.
As this is the core version of the Close method it is intended to be overridden in inherited version of the class. When overriding you will be responsible freeing any state you have maintained and getting the class ready to serialization if necessary. Note that the object may be opened again so you want to make sure you can open and close the object multiple tiles without any ill effects. In this override we call the Proj4 methods get release the handles and memory.
  • Description:None
ConvertToExternalProjectionCore(Double[],Double[])
This method returns a projected vertex based on the coordinates passed in.
This method returns a projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections.
  • Type:Vertex[]
  • Description:This method returns a projected vertices based on the coordinates passed in.
  • x
    • Type:Double[]
    • Description:This parameter is the X values of the points that will be projected.
  • y
    • Type:Double[]
    • Description:This parameter is the Y values of the points that will be projected.
ConvertToInternalProjectionCore(Double[],Double[])
This method returns a de-projected vertex based on the coordinates passed in.
This method returns a de-projected vertex based on the coordinates passed in. You will need to override this method for the Projection class. Typically you can call the projection utility library that has interfaces for dozens of different types of projections. The de-projection is important because inside of the FeatureSource you will in many cases to to and from various projections.
  • Type:Vertex[]
  • Description:This method returns a de-projected vertices based on the coordinates passed in.
  • x
    • Type:Double[]
    • Description:This parameter is the X values of the points that will be de-projected.
  • y
    • Type:Double[]
    • Description:This parameter is the Y values of the points that will be de-projected.
ConvertToExternalProjectionCore(GeoImage,RectangleShape)
ConvertToExternalProjectionCore(GeoImage,RectangleShape,RectangleShape)
GetInternalGeographyUnitCore()
GetExternalGeographyUnitCore()
CloneDeepCore()
SzE=(Feature)
  • feature
TDE=(Feature)
  • feature
DecimalDegreeBoundary
This property specifies the Boundary for decimaldegree values.
The default boundary is(-179.9, 89.9, 179.9, -89.9). That means when I want to project a PointShape(-179,91,89.91) out, in fact what it projects is (-179.9,89.9) because of its out of boundary.
Gets or sets the Proj4 text parameter for the from projection. This parameter typically look like “+Proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”.
Gets or sets the Proj4 text parameter for the to projection. This parameter typically look like “+proj=utm +zone=33 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”.
IsOpen
CanConvertRasterToExternalProjection
CanReproject
thinkgeo.mapsuite.portablecore.unmanagedproj4projection.txt · Last modified: 2017/03/16 21:59 (external edit)
