thinkgeo.mapsuite.mvcedition.resourcedeploymentmode
ThinkGeo.MapSuite.MvcEdition.ResourceDeploymentMode
This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
Items
Automatic
  • Summary:The application depolys the map image resources to “~/theme/default/img/” on the fly.
Manual
  • Summary:The application will not copy teh map image re
thinkgeo.mapsuite.mvcedition.resourcedeploymentmode.txt · Last modified: 2017/03/16 21:59 (external edit)
