thinkgeo.mapsuite.mvcedition.mapentitymodelbinder
ThinkGeo.MapSuite.MvcEdition.MapEntityModelBinder
    • ThinkGeo.MapSuite.MvcEdition.EntityModelBinder
      • ThinkGeo.MapSuite.MvcEdition.MapEntityModelBinder
MapEntityModelBinder()
BindModel(ControllerContext,ModelBindingContext)
  • controllerContext
    • Type:ControllerContext
  • bindingContext
    • Type:ModelBindingContext
BindModelCore(ControllerContext,ModelBindingContext)
  • controllerContext
  • bindingContext
9RM=(Map,String)
  • result
    • Type:Map
  • mapString
9hM=(Map,String)
  • result
    • Type:Map
  • vectorJsonString
9xM=(Map,String)
  • result
    • Type:Map
  • simpleMarkerOverlaysJsonString
thinkgeo.mapsuite.mvcedition.mapentitymodelbinder.txt · Last modified: 2017/03/16 21:59 (external edit)
