thinkgeo.mapsuite.mvcedition.bingmapsoverlay
ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay
Represents an overlay object that gets images from Microsoft's Virtual Earth server.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay
BingMapsOverlay()
  • Initialize an instance of the VirtualEarthOverlay class.
BingMapsOverlay(String)
  • Initialize an instance of the VirtualEarthOverlay class with the overlay identifier specified.
  • id
    • Description:The identifier that will be used to find the overlay.
BingMapsOverlay(String,BingMapsStyle)
  • Initialize an instance of the VirtualEarthOverlay class with the overlay identifier and Virtual Earth map type specified.
  • id
  • bingMapsMapType
BingMapsOverlay(BingMapsStyle)
  • bingMapsMapType
BingMapsOverlay(BingMapsStyle,String)
  • Initialize an instance of the VirtualEarthOverlay class with the bingMaps map type and credentials.
  • bingMapsMapType
  • credentials
    • Description:the Bing Maps key registered from https://www.bingmapsportal.com/, it will be used to authenticate against any of the REST Services APIs.
BingMapsOverlay(String,BingMapsStyle,String)
  • id
  • credentials
BingMapsOverlay(String,String)
  • Initialize an instance of the BingMapOverlay class with the overlay identifier, bingMaps map type and bingMapsKey.
  • id
  • bingMapsKey
BingMapsOverlay(String,String,BingMapsStyle)
  • id
  • bingMapsKey
  • bingMapsMapStyle
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
ToJson()
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
Credentials
Gets or sets the Bing Maps key registered from https://www.bingmapsportal.com/, it will be used to authenticate against any of the REST Services APIs.
BingMapsKey
MapType
Gets or sets a value to display which type of Virtual Earth map.
MapStyle
OnClientAutoRefreshTick
Don't support auto tick event by default.
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates the overlay type.
ERQ=
thinkgeo.mapsuite.mvcedition.bingmapsoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
