thinkgeo.mapsuite.mvcedition.markeroverlay
ThinkGeo.MapSuite.MvcEdition.MarkerOverlay
Serves as the base class for the overlay that generates and manages markers.
MarkerOverlay()
  • Initialize a new instance of the MarkerOverlay class.
MarkerOverlay(String)
  • Initialize a new instance of the MarkerOverlay class using the identifier specified.
  • id
    • Description:The identifier string of the MarkerOverlay.
DataBindTo(String,String)
  • controllerName
  • actionName
GetMarkers(RectangleShape,Int32)
  • Returns a collection of markers based on the extent and zoomlevel that you passed in.
  • The GetMarkers method creates the makrers based on the current zoomlevel, the specified extent and the special logic of the MarkerOverlay. The returned markers object will be serialized and sent to the client to create client markers.
  • Type:Collection<Marker>
  • Description:A collection of marker objects that will be serialized to the client.
  • worldExtent
    • Description:The extent that includes all of the markers you want to serialize.
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel the map is currently at.
ToJson()
FromJson(String)
  • jsonString
GetMarkersCore(RectangleShape,Int32)
  • The GetMarkersCore method allows derived classes to rewrite the logic used for dynamically creating the markers that will be serialized to the client.
  • Description:A collection of Marker objects that will be serialized to the client.
  • worldExtent
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
The MarkerOverlay can only be a non-base overlay. If you set the IsBaseOverlay property to true, there will be an exception thrown.
OnClientClick
Gets or sets a client function name which will be executed after clicking on the MarkerOverlay
There is a default parameter:e, which includes two parameters: “worldXY”, “overlayId”
OnClientMarkersRequesting
OnClientMarkersRequested
ActionTriggers
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
Id
OnClientAutoRefreshTick
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates the overlay type.
IsDefault
Gets or sets whether using default configuration.
TRU=
ERQ=
thinkgeo.mapsuite.mvcedition.markeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
