thinkgeo.mapsuite.mvcedition.layeroverlaysetting
ThinkGeo.MapSuite.MvcEdition.LayerOverlaySetting
A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
LayerOverlaySetting(LayerOverlay)
  • Initializes a new instance of the LayerOverlaySetting class.
ClientCache(ClientCache)
  • Set clientCache for Element property and retun the LayerOverlaySetting
  • clientCache
    • Description:A clientCache for Element property
IsMultiThreadDisabled(Boolean)
  • Set isMultiThreadDisabled for Element property and retun the LayerOverlaySetting
  • isMultiThreadDisabled
    • Description:A isMultiThreadDisabled for Element property
JpegQuality(Int32)
  • Set jpegQuality for Element property and retun the LayerOverlaySetting
  • jpegQuality
    • Description:A jpegQuality for Element property
Layer(Layer)
  • Set layer for Element property and retun the LayerOverlaySetting
  • layer
    • Type:Layer
    • Description:A layer for Element property
Layer(String,Layer)
  • Set layer with a specific key for Element property and retun the LayerOverlaySetting
  • key
    • Description:A key uses for layer
  • layer
    • Type:Layer
ServerCache(ServerCache)
  • Set serverCache for Element property and retun the LayerOverlaySetting
  • serverCache
    • Description:A serverCache for Element property
TileWidth(Int32)
  • Set tileWidth for Element property and retun the LayerOverlaySetting
  • tileWidth
    • Description:A tileWidth for Element property
TileHeight(Int32)
  • Set tileHeight for Element property and retun the LayerOverlaySetting
  • tileHeight
    • Description:A tileHeight for Element property
TileMargin(Int32)
  • Set tileMargin for Element property and retun the LayerOverlaySetting
  • tileMargin
    • Description:A tileMargin for Element property
TileType(TileType)
  • Set tileType for Element property and retun the LayerOverlaySetting
  • tileType
    • Type:TileType
    • Description:A tileType for Element property
TransitionEffect(TransitionEffect)
  • Set transitionEffect for Element property and retun the LayerOverlaySetting
  • transitionEffect
TransitionEffectDelayInMilliseconds(Int32)
  • transitionEffectDelayInMilliseconds
WebImageFormat(WebImageFormat)
  • Set webImageFormat for Element property and retun the LayerOverlaySetting
  • webImageFormat
    • Description:A webImageFormat for Element property
WrapDateline(WrapDatelineMode)
  • Set wrapDateline for Element property and retun the LayerOverlaySetting
  • wrapDateline
SetBaseEpsgProjection(String)
  • Set epsg for Element property and retun the LayerOverlaySetting
  • epsg
    • Description:A epsg for Element property
DataBindTo(String,String)
  • controllerName
  • actionName
ActionTriggers(Action<Collection<ActionTrigger»)
  • triggerActions
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.layeroverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
