Represents an Overlay that contains layers.
LayerOverlay(String,Boolean,TileType)
Draw(GeoCanvas,Object,RectangleShape,GeographyUnit)
GenerateCacheImages(ZoomLevel,RectangleShape,GeographyUnit)
GenerateCacheImages(Double,RectangleShape,GeographyUnit)
DrawCore(GeoCanvas,Object,RectangleShape,GeographyUnit)
Gets or sets the number of extra rows and colums of tiles on each side that will surround the minimum grid tiles to cover the map. Used only when in MultipleTile mode.
Gets or sets the ClientCache object that contains the configuration for the browser cache of this overlay.
Gets or sets the format of the image that is sent to the web browser.
Gets or sets the quality of the JPEG image that is sent to the web browser. Valid values are between 1 - 100, inclusive.
The JpegQuality property determines the quality of the JPEG image that is sent to the browser if the WebImageFormat is Jpeg. Setting this property to a lower value will reduce the image filesize. The value must be between 1 - 100. The default is 100.
Gets a GeoCollection that contains the layers that will draw on the image that is sent to the browser.
The Layers property holds all of the layers that are used by the Draw method. The Draw method loops through all layers to filter out features and draw with specified styles to the image that will be sent to the browser.
Gets or sets a value that indicates whether the overlay is visible on the map.
Gets or sets a value that indicates whether the overlay wraps at the date line.
