thinkgeo.mapsuite.androidedition.controlpointselectingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
ControlPointSelectingEditInteractiveOverlayEventArgs()
ControlPointSelectingEditInteractiveOverlayEventArgs(Boolean,PointShape)
  • cancel
  • targetPointShape
    • Description:This parameter specified the target control point to be selected.
TargetPointShape
  • This property gets or sets the target control point to be selected.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.controlpointselectingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
