thinkgeo.mapsuite.mvcedition.mvcelementsettingbase_telement_tsetting
ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase‹TElement,_TSetting›
<!– Class –> This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
Protected MethodMvcElementSettingBase‹TElement, TSetting› Initializes a new instance of MvcElementSettingBase.
Protected MethodMvcElementSettingBase‹TElement, TSetting› TElement
Public MethodGetType Object
Public MethodToString Object
Protected PropertyElement TElement MvcElementSettingBase<TElement,TSetting> Gets the element.
MvcElementSettingBase‹TElement, TSetting›()
Name Type Description
Go Back
MvcElementSettingBase‹TElement, TSetting›(TElement)
mapElement TElement<!– TElement –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Element
Gets the element.
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{TElement,TSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.mvcelementsettingbase_telement_tsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
