<!– Class –> A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
*System.Object **ThinkGeo.MapSuite.MvcEdition.OverlaySetting‹TOverlay, TSetting›
OverlaySetting‹TOverlay, TSetting› | Initializes a new instance of the OverlaySetting class. | ||
OverlaySetting‹TOverlay, TSetting› | TOverlay |
AutoRefreshInterval | TimeSpan | OverlaySetting<TOverlay,TSetting> | Sets timeSpan for Element property and retun the OverlaySetting |
Id | String | OverlaySetting<TOverlay,TSetting> | Sets id for Element property and retun the OverlaySetting |
IsBaseOverlay | Boolean | OverlaySetting<TOverlay,TSetting> | Sets isBaseOverlay for Element property and retun the OverlaySetting |
IsVisible | Boolean | OverlaySetting<TOverlay,TSetting> | Sets isVisible for Element property and retun the OverlaySetting |
IsVisibleInOverlaySwitcher | Boolean | OverlaySetting<TOverlay,TSetting> | Sets isVisibleInOverlaySwitcher for Element property and retun the OverlaySetting |
Name | String | OverlaySetting<TOverlay,TSetting> | Sets name for Element property and retun the OverlaySetting |
OnClientAutoRefreshTick | String | OverlaySetting<TOverlay,TSetting> | Sets the JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed. |
Opacity | Single | OverlaySetting<TOverlay,TSetting> | Sets opacity for Element property and retun the OverlaySetting |
Element | TOverlay | MvcElementSettingBase<TOverlay,TSetting> |
| overlay | TOverlay<!– TOverlay –> |
| TSetting<!– TSetting –> | The setting of OverlaySetting itself |
| timeSpan | TimeSpan<!– System.TimeSpan –> | A timeSpan for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{TOverlay,TSetting} –> Go Back
| id | String<!– System.String –> | A id for Element property |
| isBaseOverlay | Boolean<!– System.Boolean –> | A isBaseOverlay for Element property |
| isVisible | Boolean<!– System.Boolean –> | A isVisible for Element property |
| isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> | A isVisibleInOverlaySwitcher for Element property |
| name | String<!– System.String –> | A imageUri for Element property |
| TSetting<!– TSetting –> | The setting of OverlaySetting itself. |
| clientTickFunctionName | String<!– System.String –> | The JavaScript function name. |
| opacity | Single<!– System.Single –> | A opacity for Element property |
<!– MvcElementSettingBase{TOverlay,TSetting} –> Go Back
