thinkgeo.mapsuite.mvcedition.mvccontrolcollection
ThinkGeo.MapSuite.MvcEdition.MvcControlCollection
Represents the Mvc control's factory.
    • ThinkGeo.MapSuite.MvcEdition.MvcControlCollection
MvcControlCollection(HtmlHelper)
  • Initializes a new instance of MvcControlCollection
  • htmlHelper
    • Type:HtmlHelper
    • Description:The htmlHelper.
Map()
  • Creates a new instance of Map.
Map(String)
  • Creates a new instance of Map with specified name.
  • name
    • Description:The name of the map.
Map(String,Unit,Unit)
  • Creates a new instance of Map with specified name, width and height.
  • name
  • width
    • Type:Unit
    • Description:Width of the map.
  • height
    • Type:Unit
    • Description:Height of the map.
Map(Map)
  • Initializes a new Configuration with specified map object.
  • map
    • Type:Map
    • Description:The map object.
WxY=
  • Type:HtmlHelper
thinkgeo.mapsuite.mvcedition.mvccontrolcollection.txt · Last modified: 2017/03/16 21:59 (external edit)
