thinkgeo.mapsuite.mvcedition.pointmarkerstylesetting
ThinkGeo.MapSuite.MvcEdition.PointMarkerStyleSetting
A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
PointMarkerStyleSetting(PointMarkerStyle)
  • Initializes a new instance of the PointMarkerStyleSetting class.
Popup(Action<CustomPopupSetting>)
  • Set Popup for Element property according to a method that takes CustomPopupSetting and retun the PointMarkerStyleSetting
  • popupAction
PopupDelay(Int32)
  • Set popupDelay for Element property and retun the PointMarkerStyleSetting
  • popupDelay
    • Description:A popupDelay for Element property
WebImage(WebImage)
  • Set webImage for Element property and retun the PointMarkerStyleSetting
  • webImage
    • Type:WebImage
    • Description:A webImage for Element property
ContextMenu(Action<ContextMenuSetting>)
  • Set ContextMenu for Element property according to a method that takes ContextMenuSetting and retun the PointMarkerStyleSetting
Opacity(Single)
  • Set opacity for Element property and retun the PointMarkerStyleSetting
  • opacity
    • Type:Single
    • Description:A opacity for Element property
Element
thinkgeo.mapsuite.mvcedition.pointmarkerstylesetting.txt · Last modified: 2017/03/16 21:59 (external edit)
