thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlaysetting
ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting
A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
WorldMapKitWmsWebOverlaySetting(WorldMapKitWmsWebOverlay)
  • Initializes a new instance of the WorldMapKitWmsWebOverlaySetting class.
WebImageFormat(WebImageFormat)
  • Set webImageFormat for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • webImageFormat
    • Description:A webImageFormat for Element property
TileWidth(Int32)
  • Set tileWidth for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • tileWidth
    • Description:A tileWidth for Element property
TileHeight(Int32)
  • Set tileHeight for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • tileHeight
    • Description:A tileHeight for Element property
TransitionEffect(TransitionEffect)
  • Set transitionEffect for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • transitionEffect
TransitionEffectDelayInMilliseconds(Int32)
  • transitionEffectDelayInMilliseconds
TileType(TileType)
  • Set tileType for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • tileType
    • Type:TileType
    • Description:A tileType for Element property
WrapDateline(WrapDatelineMode)
  • Set wrapDateline for Element property and retun the WorldMapKitWmsWebOverlaySetting
  • wrapDateline
Projection(WorldMapKitProjection)
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
