thinkgeo.mapsuite.mvcedition.scalelinemaptoolsetting
ThinkGeo.MapSuite.MvcEdition.ScaleLineMapToolSetting
A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
ScaleLineMapToolSetting(ScaleLineMapTool)
  • Initializes a new instance of the ScaleLineMapToolSetting class.
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.scalelinemaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
