thinkgeo.mapsuite.mvcedition.highlightfeatureoverlaysetting
ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlaySetting
A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
HighlightFeatureOverlaySetting(HighlightFeatureOverlay)
  • Initializes a new instance of the HighlightFeatureOverlaySetting class.
ContextMenu(ContextMenu)
  • Set contextMenu for Element property and retun the HighlightFeatureOverlaySetting
  • contextMenu
    • Description:A contextMenu for Element property
HighlightStyle(FeatureOverlayStyle)
  • Set highlightStyle for Element property and retun the HighlightFeatureOverlaySetting
OnClientClick(String)
  • Set onClientClick javascript function name for Element property and retun the HighlightFeatureOverlaySetting
  • onClientClick
    • Description:A onClientClick javascript function name for Element property
Columns(Action<Collection<FeatureSourceColumn»)
EditTools(EditTools)
Feature(Feature)
  • feature
Feature(String,Feature)
  • key
  • feature
FeatureSource(InMemoryFeatureSource)
QueryTools(QueryTools)
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.highlightfeatureoverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
