map_suite_gps_tracking_server_web_services_reference_guide
Map Suite GPS Tracking Server Web Services Reference Guide
This is a complete list of the methods exposed in the Map Suite GPS Tracking Server web portal web services. These services allow you to manipulate your Map Suite GPS Tracking Server web portal accounts, users, departments, devices and more.
The web service APIs are divided into two groups: Account APIs and Installation APIs. The scope of the Account APIs is a single account within your Map Suite GPS Tracking Server system; these allow you to manipulate that account's devices, users, departments and so on. The Installation APIs, by contrast, have a scope encompassing the entire GPS Tracking Server system. These give you access to creation and deletion of accounts and frontend language packs on the server.
Account Web Service APIs
WSOrganizationManager Web Service
GetOrganizationsForAccount method
Parameters:
securityKeyRequired, user ID
accountIDRequired, Account ID
Return value: String
Function description: Gets an organization from an account.
GetAllOrganizationForAccount method
Parameters:
userNameRequired, user name for authentication
passwordRequired, password for authentication
Function description: Gets all organizations from an account.
GetOrganization method
Parameters:
orgIDRequired, Organization ID
Function description: Gets an organization.
CreateOrganization method
Parameters:
accountIDRequired, account ID
orgNameRequired, organization name
DescriptionOrganization description
mapDataIDRequired, map Data ID
timeZoneRequired, time zone of the organization's location
metricRequired, selects whether the organization's unit system is metric or imperial
statusRequired, organization status, must be ACTIVE or INACTIVE, default is ACTIVE
externalIDReserved field
Return value: OrganizationID
Function description: Creates an organization.
EditOrganization method
Parameters:
orgIDRequired, organization ID
descriptionOrganization description
managerManager of the organization
imageNameThe path of the organization image
mapDataIDRequired, map data ID
Function description: Edits an organization.
DeleteOrganization method
Parameters:
Function description: Deletes an organization in the system.
OrganizationAddDevice method
Parameters:
deviceIDRequired, device ID
Function description: Adds a device to an organization.
OrganizationAddCarrier method
Parameters:
carrierIDRequired, carrier ID
Function description: Adds a carrier to an organization.
OrganizationAddMonitor method
Parameters:
monitorIDRequired, monitor ID
Function description: Adds a monitor to an organization.
GetCarriersForOrganization method
Parameters:
Function description: Gets the carriers in an organization.
GetDevicesForOrganization method
Parameters:
Function description: Gets the devices in an organization.
GetMonitorsForOrganization method
Parameters:
Function description: Gets the monitors in an organization.
DeleteOrganizationCarrier method
Parameters:
Function description: Deletes a carrier from an organization.
DeleteOrganizationDevice method
Parameters:
Function description: Deletes a device from an organization.
DeleteOrganizationMonitor method
Parameters:
Function description: Deletes a monitor from an organization.
GetAllMapDataForAccount method
Parameters:
Function description: Gets all available map data for an account.
WSMonitorManager Web Service
CreateMonitor method
Parameters:
adminUserNameRequired, admin user name for authentication
adminUserNameRequired, admin password for authentication
nameRequired, Monitor name
descriptionMonitor description
entryReference
Dashboard or Map Area|
statusRequired, monitor status, must be ACTIVE or INACTIVE, default is ACTIVE
Return value: MonitorID
Function description: Creates a monitor.
EditMonitor method
adminPasswordRequired, admin password for authentication
monitorIDMonitor ID
nameRequired, monitor name
entryReference
Function description: Edits a monitor.
DeleteMonitor method
Parameters:
MonitorIDRequired, monitor ID
Function description: Deletes a monitor from the system.
GetMonitor method
Parameters:
Function description: Gets a monitor.
GetMonitorsForAccount method
Parameters:
Function description: Gets monitors from an account.
Parameters:
Function description: Gets monitors from an organization.
WSUserManager Web Service
GetUsersForAccount method
Parameters:
Function description: Gets users from an account.
GetUser method
Parameters:
userIDRequired, user ID
Function description: Gets a user.
CreateUser method
Parameters:
statusRequired, user status, must be ACTIVE or INACTIVE, default is ACTIVE
entryReference
firstNameFirst name
lastNameLast name
emailAddressEmail address
activateDateActivation date
deactiveDateDeactivation date
allowMultipleSessionsWhether to enable multiple sessions, which allow the same user to be logged in more than once simultaneously
checkMessageIntervalCheck message interval
Return value: UserID
Function description: Creates a user.
EditUser method
Parameters:
entryReference
firstNameFirst name
lastNameLast name
Function description: Edits a user.
DeleteUser method
Function description: Deletes a user from the system.
ChangeUserPassword method
newPasswordRequired, new password
Function description: Change a user's password.
IsUserNameInUse method
Parameters:
usernameRequired, the user name to check for
Function description: Checks whether a specified username is in use.
IsEmailInUse method
Parameters:
emailAddressRequired, the email address to check for
Return value: bool
Function description: Checks whether a specified user email address is in use.
WSDeviceManager Web Service
Parameters:
organizationIDRequired, organization ID
Function description: Gets the devices from an organization.
GetDevicesForAccount method
Parameters:
accountidRequired, account ID
Function description: Gets the devices from an account.
GetAllDevicesForOrganization method
Parameters:
Function description: Gets all devices from an organization.
GetDeviceCategories method
Parameters:
Function description: Gets the device categories.
GetDevice method
Parameters:
Function description: Gets a device.
CreateDevice method
Parameters:
deviceNameRequired, device name
descriptionDevice description
topSpeedRequired, top speed
statusRequired, device status, must be ACTIVE or INACTIVE, default is ACTIVE
imeiRequired, International Mobile Equipment Identifier (IMEI) or Electronic Identifier (EID) of the wireless modem
cannedMessage
way communication|
deviceCategoryIDDevice category ID
colorCodeChoose a color to associate with the device, default is a random color
Return value: DeviceID
Function description: Creates a device.
EditDevice method
Parameters:
DeviceIDRequired, device ID
cannedMessage
way communication|
Function description: Edits a carrier.
DeleteDevice method
Parameters:
Function description: Delete a device from the system.
WSCarrierManager Web Service
GetCarriersForAccount method
Parameters:
Function description: Gets the carriers from an account.
Parameters:
Function description: Gets the carriers from an organization.
GetCarriersDevice method
Parameters:
Function description: Gets a carrier's device.
GetCarriers method
Parameters:
Function description: Gets a carrier.
CreateCarrier method
Parameters:
carrierNameRequired, carrier name
carrierPinCarrier's personal identification number, the default value is 0000
statusRequired, carrier status, must be ACTIVE or INACTIVE, default is ACTIVE
Return value: CarrierID
Function description: Creates a carrier.
EditCarrier method
Parameters:
descriptionRequired, description of the carrier
otherInformationOther information about the carrier, HTML supported. Will be displayed in a popup bubble on the tracking screen.
DeleteCarrier method
Parameters:
Function description: Deletes a carrier from the system.
CarrierAddDevice method
Parameters:
Function description: Assigns a device to a carrier.
CarrierDeleteDevice method
Parameters:
Function description: Disassociates a device from a carrier.
WSAlertManager Web Service
LoadEventResponseForAccount method
Parameters:
serverityRequired, serverity level
Function description: Loads an event response for an account.
LoadEventResponseForOrganization method
Parameters:
Function description: Loads an event response for an organization.
EditEventResponseForAccount method
Parameters:
additionalEmailAddressesRequired
alertPopupActionRequired, popup action
alertThresholdRequired, alert threshold
friendlyNameRequired, friendly name
iconPathRequired
noisePathRequired
overriddenRequired
overridesRequired
repeatRequired
sendEmailRequired
severityColorRequired
Function description: Edits an event response for an account.
EditEventResponseFor Organization method
Parameters:
iconPathRequired
noisePathRequired
overriddenRequired
overridesRequired
repeatRequired
sendEmailRequired
Function description: Edits an event response for an organization.
WSLocationManager Web Service
CreateLocation method
Parameters:
adminUserNameRequired, user name for authentication
adminPasswordRequired, password for authentication
IMEIRequired, Device IMEI
locationIDRequired, New Guid
logTimeRequired, GPS date time of message
yPointRequired, Latitude
xPointRequired, Longitude
altitudeRequired, altitude
speedRequired, device speed
travelDirectionRequired, Travel Direction
speedUncertaintyRequired, Speed Uncertainty or not
responseCodeRequired
assistanceUsedRequired
Return value: LocationID
Function description: Create a location for device.
GetCurrentLocationByDevice method
Parameters:
deviceIDRequired
Function description: Get current location for the device.
GetLocationBySession method
Parameters:
lsessionDRequired
Function description: Get locations for the session.
Installation Web Service APIs
WSAccountManager Web Service
CreateAccount method
Parameters:
installUserNameRequired, installer user name for authentication
installPasswordRequired, installer password for authentication
adminUserNameRequired, admin user name for the account
accountNameRequired, account name
statusRequired, account status, must be ACTIVE or INACTIVE, default is ACTIVE
activateDateAccount activation date
deactivateDateAccount deactivation date
manageSecurityCan manage security or not
manageBrandCan manage brand or not
processLocationInfoCan process LocationInformation of map or not in account level
termsOfUseCan use terms of use or not
orgLimitOrganization limit, default is -1 (unlimited)
monitorLimitMonitor limit, default is -1 (unlimited)
carrierLimitCarrier limit, default is -1 (unlimited)
deviceLimitDevice limit, default is -1 (unlimited)
targetLimitTarget limit, default is -1 (unlimited)
areaLimitArea limit, default is -1 (unlimited)
securityPath
Factor Authentication is enabled in Account General Settings, the security binary path will be used to judge whether or not this account is TwoFactorSecurity Valid when a user logs in.|
Return value: AccountID
Function description: Creates an account at the installer level.
GetAccount method
Parameters:
Function description: Checks to see whether the account exists in the system.
GetAllAccounts method
Parameters:
Function description: Gets all of the accounts under this installation.
EditAccount method
Parameters:
manageBrandCan manage branding or not
processLocationInfoCan process LocationInformation of the map at the account level or not
termsOfUseCan apply Terms of Use or not
securityPath
Function description: Edits an account at the installer level.
DeleteAccount method
Parameters:
Function description: Deletes an account in the system at the installer level.
WSLanguageManager Web Service
GetLanguageList method
Parameters:
Function description: Gets a list of languages available in the installation.
GetLanguage method
Parameters:
languageIDRequired, language ID
Function description: Gets a language.
GetSystemLanguageList method
Parameters:
Function description: Gets a list of the available system languages.
LanguageDelete method
Parameters:
Function description: Deletes a language.
CreateLanguage method
Parameters:
languageNameRequired, language name
isSystemRequired
StatusRequired, status
Function description: Creates a new language.
EditLanguage method
Parameters:
isSystemRequired
Function description: Edits a language.
SetLanguageForUser method
Parameters:
Function description: Sets the language for a user.
map_suite_gps_tracking_server_web_services_reference_guide.txt · Last modified: 2015/09/16 06:03 by admin
