thinkgeo.mapsuite.mvcedition.panzoommaptoolsetting
ThinkGeo.MapSuite.MvcEdition.PanZoomMapToolSetting
A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
PanZoomMapToolSetting(PanZoomMapTool)
  • Initializes a new instance of the PanZoomMapToolSetting class.
IsGlobeButtonEnabled(Boolean)
  • Set IsGlobeButtonEnabled for Element property and retun the PanZoomMapToolSetting
  • IsGlobeButtonEnabled
    • Description:A IsGlobeButtonEnabled for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.panzoommaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
