thinkgeo.mapsuite.mvcedition.markeroverlaysetting_toverlay_tsetting
ThinkGeo.MapSuite.MvcEdition.MarkerOverlaySetting‹TOverlay,_TSetting›
<!– Class –> A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
Protected MethodMarkerOverlaySetting‹TOverlay, TSetting› Initializes a new instance of the MarkerOverlaySetting class.
Protected MethodMarkerOverlaySetting‹TOverlay, TSetting› TOverlay
Public MethodAutoRefreshInterval TimeSpan OverlaySetting<TOverlay,TSetting>
Public MethodGetType Object
Public MethodId String OverlaySetting<TOverlay,TSetting>
Public MethodIsBaseOverlay Boolean OverlaySetting<TOverlay,TSetting>
Public MethodIsVisible Boolean OverlaySetting<TOverlay,TSetting>
Public MethodIsVisibleInOverlaySwitcher Boolean OverlaySetting<TOverlay,TSetting>
Public MethodName String OverlaySetting<TOverlay,TSetting>
Public MethodOnClientAutoRefreshTick String OverlaySetting<TOverlay,TSetting>
Public MethodOnClientClick String MarkerOverlaySetting<TOverlay,TSetting> Set OnClientClick handler name for Element property according to a method that takes a client function name and retun the MarkerOverlaySetting
Public MethodOpacity Single OverlaySetting<TOverlay,TSetting>
Public MethodToString Object
Protected PropertyElement TOverlay MvcElementSettingBase<TOverlay,TSetting>
MarkerOverlaySetting‹TOverlay, TSetting›()
Name Type Description
Go Back
MarkerOverlaySetting‹TOverlay, TSetting›(TOverlay)
markerOverlay TOverlay<!– TOverlay –>
Go Back
AutoRefreshInterval(TimeSpan)
Return Type Description
TSetting<!– TSetting –>
timeSpan TimeSpan<!– System.TimeSpan –>
<!– OverlaySetting{TOverlay,TSetting} –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Id(String)
id String<!– System.String –>
IsBaseOverlay(Boolean)
isBaseOverlay Boolean<!– System.Boolean –>
IsVisible(Boolean)
isVisible Boolean<!– System.Boolean –>
IsVisibleInOverlaySwitcher(Boolean)
isVisibleInOverlaySwitcher Boolean<!– System.Boolean –>
Name(String)
name String<!– System.String –>
OnClientAutoRefreshTick(String)
clientTickFunctionName String<!– System.String –>
OnClientClick(String)
TSetting<!– TSetting –> The setting of MarkerOverlaySetting itself
clientEventHandler String<!– System.String –>
<!– ThinkGeo.MapSuite.MvcEdition.MarkerOverlaySetting{TOverlay,TSetting} –> Go Back
Opacity(Single)
opacity Single<!– System.Single –>
Void<!– System.Void –>
Element
Return Type
<!– MvcElementSettingBase{TOverlay,TSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.markeroverlaysetting_toverlay_tsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
