thinkgeo.mapsuite.mvcedition.minimapmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting
A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
MiniMapMapToolSetting(MiniMapMapTool)
  • Initializes a new instance of the MiniMapMapToolSetting class.
MaximizeRatio(Int32)
  • Set maximize Ratio of map for Element property and retun the MiniMapMapToolSetting
  • maximizeRatio
    • Description:A maximize Ratio of map for Element property
MinimizeRatio(Int32)
  • Set minimize Ratio of map for Element property and retun the MiniMapMapToolSetting
  • minimizeRatio
    • Description:A minimize Ratio of map for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.minimapmaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
