<!– Class –> A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
FeatureOverlaySetting‹TOverlay, TSetting› | Initializes a new instance of the FeatureOverlaySetting class. | ||
FeatureOverlaySetting‹TOverlay, TSetting› | TOverlay |
AutoRefreshInterval | TimeSpan | OverlaySetting<TOverlay,TSetting> | |
Columns | Action<Collection<FeatureSourceColumn» | FeatureOverlaySetting<TOverlay,TSetting> | |
EditTools | EditTools | FeatureOverlaySetting<TOverlay,TSetting> | Set editTools for Element property and retun the FeatureOverlaySetting |
Feature | Feature | FeatureOverlaySetting<TOverlay,TSetting> | Set imageUri for Element property and retun the FeatureOverlaySetting |
Feature | String, Feature | FeatureOverlaySetting<TOverlay,TSetting> | Set imageUri for Element property and retun the FeatureOverlaySetting |
FeatureSource | InMemoryFeatureSource | FeatureOverlaySetting<TOverlay,TSetting> | Set imageUri for Element property and retun the FeatureOverlaySetting |
Id | String | OverlaySetting<TOverlay,TSetting> | |
IsBaseOverlay | Boolean | OverlaySetting<TOverlay,TSetting> | |
IsVisible | Boolean | OverlaySetting<TOverlay,TSetting> | |
IsVisibleInOverlaySwitcher | Boolean | OverlaySetting<TOverlay,TSetting> | |
Name | String | OverlaySetting<TOverlay,TSetting> | |
OnClientAutoRefreshTick | String | OverlaySetting<TOverlay,TSetting> | |
Opacity | Single | OverlaySetting<TOverlay,TSetting> | |
QueryTools | QueryTools | FeatureOverlaySetting<TOverlay,TSetting> | Set imageUri for Element property and retun the FeatureOverlaySetting |
Style | FeatureOverlayStyle | FeatureOverlaySetting<TOverlay,TSetting> | Set imageUri for Element property and retun the FeatureOverlaySetting |
Element | TOverlay | MvcElementSettingBase<TOverlay,TSetting> |
| featureOverlay | TOverlay<!– TOverlay –> |
| TSetting<!– TSetting –> |
| timeSpan | TimeSpan<!– System.TimeSpan –> |
<!– OverlaySetting{TOverlay,TSetting} –> Go Back
| columnsAction | Action<Collection<FeatureSourceColumn»<!– System.Action{System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn}} –> |
<!– ThinkGeo.MapSuite.MvcEdition.FeatureOverlaySetting{TOverlay,TSetting} –> Go Back
| TSetting<!– TSetting –> | The setting of FeatureOverlaySetting itself |
| editTools | EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> | A editTools for Element property |
| feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
| key | String<!– System.String –> | |
| featureSource | InMemoryFeatureSource<!– ThinkGeo.MapSuite.Core.InMemoryFeatureSource –> |
| id | String<!– System.String –> |
| isBaseOverlay | Boolean<!– System.Boolean –> |
| isVisible | Boolean<!– System.Boolean –> |
| isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> |
| name | String<!– System.String –> |
| clientTickFunctionName | String<!– System.String –> |
| opacity | Single<!– System.Single –> |
| queryTools | QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
| style | FeatureOverlayStyle<!– ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyle –> |
<!– MvcElementSettingBase{TOverlay,TSetting} –> Go Back
