A
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents the advanced drawing options for area styles.
This class is a collection of predefined styles and helper methods for creating styles.
B
This class draws the background of the map.
The abstract class from which area shapes, line shapes, and point shapes inherit from.
This class represents the zoom levels used by Bing Maps.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This class draws the parcel featureLayer of the map.
This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
C
This class formats a GeoObjectModel into C# code.
This class represents a single class break.
This class represents a style based on class break values.
This static class provides a conversion method to go to and from different units.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
D
This class represents the column information specific to a DBF column.
This class allows you to display information by drawing points on an area based on a value from the features data.
E
This class represents an ECW image to be drawn on the map.
This class represents the ECW raster source.
This class represents the parameters passed in through the ExecutingSqlStatement event in MsSql2008FeatureSource.
This class represents the parameters passed in through the ExecutingSqlStatement event in OracleFeatureSource.
This static class exposes a number of helpful methods when dealing with extents.
F
G
This class represents a canvas that is used to draw geographic shapes with GDI+.
This class represents general image types to be drawn on the map, such as .BMP, .JPG, .PNG, etc.
This class allows you to view standard .NET GDI+ image types such as BMP, TIF, JPG, and PNG.
Provides a collection of predefined GeoBrushes
This class formats a GeoObjectModel into program code.
This class generates code that recreates any given object.
This class is a collection of predefined colors
This class represents a font that is used to label features on a GeoCanvas.
This class represents a brush that fills with various patterns.
This class represents an image you want to use on the GeoCanvas.
This class represent the model of a top level object.
This class creates models for objects and recreates objects from models.
This class represent the model of an object.
This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
Provides a collection of predefined GeoPens
This class formats a GeoObjectModel into serialized data.
This class serializes an object.
This class represents a TIFF image to be drawn on the map.
This class is a convenient way to access a predefined set of geographic colors.
Represents an object that encapsulates a Google Map layer.
This class represents the zoom levels used by Google Maps.
This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
GraticuleAdornmentLayer shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
This class uses the grid file provided.
Reads cell data from a grid file and displays them in appropriate colors based on their values.
This class represents a Layer backed by a group of layers.
H
I
This class displays an icon with text from the data of the feature.
This class is a single item in an IconValueStyle.
This class allows you to choose different icons based on values in the data of a feature.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This layer is backed by memory and is typically used for temporary features.
J
This class represents a .JP2 (JPEG2000) image type to be drawn on the map.
This class represents the JPEG2000 raster source.
K
L
This class represents the location of a piece of a label that may be drawn.
This class represents a candidate for labeling.
This class is the base class for all types of Layers.
This class is the style used to draw lines.
This class is a collection of predefined styles and helper methods to create styles.
This is the sub base class of AdornmentLayer. The LogoAdornmentLayer is taken as Logo map of the Map Control.
M
This class is for generating maps.
This class represent a unit can be drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels.
Ideally I would want to make this inherit from the FeatureLayer so you could do spatial queries. In the interests of time I inherited from the Layer to make things simple and show the point of how easy it is to extend Map Suite. When we roll this into the main product we may create a FeatureSource and FeatureLayer.
This class defines the TileMatrix system used in MapSuite component.
This class represents a base Matrix which encapsulate the tile caculation logics.
This class represents a MrSid image to be drawn on the map.
This class represents the MrSid raster source.
This class represents a layer backed by Microsoft SQL 2008.
This class represents a FeatureSource backed by MS SQL 2008.
This class represents a Layer backed by multiple Shape Files.
This MultipleFeatureSource is a special FeatureSource which holds a bunch of FeatureSource.
This layer represents multiple Shape Files of the same type.
This class represents a FeatureSource backed by multiple ESRI Shape Files.
This class represents one or more point shapes.
N
This is the base class for NativeTileCache system which inherits from TileCache class.
Indicates that a type's base type should not be serialized.
O
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
This class is use for Open Street Map Layer, and you also can get map from open street map server.
This class represents the zoom levels used by Open Stree Map.
This class represents a Layer backed by Oracle Spatial.
This class represents a FeatureSource backed by Oracle Spatial.
P
Q
This is a helper class that allows you to execute various queries.
R
This abstract class is the basis for all image-based layers in the system.
This class represents a single Regex Match statement and styles to draw.
This class allows you to draw features differently based on regular expression matching.
This class represents the parameters passed in through the RequestedData event in WfsFeatureSource.
This class represents the parameters passed in through the RequestingData event in WfsFeatureSource.
This layer can show or hide one or many zones that you want to restrict from being displayed. You can use the specified style to decorate the zones and set the lower/upper scale to control at which zoom levels you want to show or hide the zones. The default decoration style is a hatch pattern. You can change this to a circle with slash image, or, if you want a different look, you can use custom styles.
This class represents a closed ring of points.
This projection allows you to rotate the map image base don an angle.
Rtree is a facade class of MapSuiteRtree.
S
The ScaleBarAdornmentLayer class allows you show a bar graphic on the map that displays the distance scale for the current map extent.
The ScaleLineAdornmentLayer is a concrete class inherited from AdornmentLayer. The ScaleLineAdornmentLayer class allows you show a ScaleLine graphic on the map.
The event args containing the event data used by TiledWmsLayerEventArgs.
The event args containing the event data used by SecuredTiledWmsRasterSource.
This class represents a Layer backed by a Shape File.
This class represents a FeatureSource backed by ESRI a Shape File.
This class stores simple label information used in the PositionStyle.
This class is a convenient way to access a predefined set of simple colors.
This class is a convenient way to access a predefined set of standard colors.
This class represents the event arguments for the StreamLoading event.
This abstract class is the root for all styles used for drawing features.
T
U
This class allows you to view TIFF image types.
This static class is a wrapper contains unsafe native methods
V
This class represents a single value to match and styles to draw.
This class allows you to match a value with data in the feature to determine how to draw that feature.
W
This class represents the wfs(web feature service) FeauteLayer.
This class represents the wfs(web feature service) FeauteSource.
Represents an object that encapsulates a Web Map Service (WMS) layer.
Represents an object that encapsulates a Web Map Service (WMS) source.
This class represents the values of a world file.
This class is use for world map kit, and you also can get map from ThinkGeo world map kit server.
X
This class formats a GeoObjectModel into XML.
Z
D
This structure represents a degrees, minutes and seconds value.
This structure represents the drawing of a rectangle in screen coordinates.
G
L
R
S
T
V
A
Units describing various ways you can measure areas.
B
In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
This enumeration represents whether an index should be rebuilt or not.
This enumeration represents whether a record ID should be rebuilt or not.
C
D
This enumeration represents the column type in the DBF.
Dbf read write mode
Units describing various ways you can measure lengths.
This enum is used to describe some choice when exception hanppens during drawing Layers or Overlays.
This enumeration specifies the type of font style for drawing text.
This enumeration represents the graphics unit.
This enumeration represents the drawing level used in the GeoCanvas.
This enumeration specifies how to join consecutive line or curve segments.
This enumeration specifies the drawing quality of the GeoCanvas.
E
This enumeration represents the type of ExcutingSqlStatement.
F
G
Specifies the direction of a linear gradient.
Indicates how the default value of a member will be dealt with by the modeler.
Indicate the kind of member that will be modeled by the modeler.
This is an enumation that indicates which way is used to read the image source.
Units describing the way geographies are stored in a data source.
This enumeration specifies the map types available from Google Maps.
This enumeration specifies the picture formats when getting images back to client from Google Maps.
I
J
K
L
This enumeration defines the different labeling duplicate rules.
This enumeration defines the rules for overlapping.
This enumeration specifies the style of dashed lines drawn with a GeoPen object.
M
This enumeration specifies the map printer layer preview draw mode.
The enumeration represents which mode will use for map resize.
O
P
This enumeration defines panning directions.
This enumeration determines whether the brush or the pen draws first.
This enumeration determines the label placement when labeling point features.
This enumeration defines the different types of PointSymbols that can be drawn.
This enumeration defines how a PointSymbol will be drawn.
Labeling Location Mode for polygon
The enumeration indicates which way are specified to read the projection information.
Q
R
Defines values represent which kind of color will use for randomly.
This enumeration defines the matching criteria for regular expression matching.
This enumeration specifies the restriction mode.
This enumeration specifies the type of restriction zone display style.
This enumeration provides some options when querying a feature.
S
Unit Mode
This enumeration represent read only or read-write nature of a Shape File.
This enumeration represents the types stored in the Shape File.
This enumeration describes the type of validation test to run on shapes.
Specifies which algorthm will be use to simplify.
This property gets the spatial data type in the MsSql2008FeatureSource.
This enumeration represents the spline type for labeling.
An enumeration describing the place to start on a line when doing certain operations.
T
U
System of measurement.
W
This describes a set of enumerations that list the valid types of geometries.
Wfs Name space.
This enumeration represents the byte order that well-known binary will be written in.
This enumeration represent read only or read-write nature of a Wkb File.
WMTS System.
This enumeration represents which projection will use for world map kit.
