thinkgeo.mapsuite.core.logoadornmentlayer
ThinkGeo.MapSuite.Core.LogoAdornmentLayer
This is the sub base class of AdornmentLayer. The LogoAdornmentLayer is taken as Logo map of the Map Control.
      • ThinkGeo.MapSuite.Core.AdornmentLayer
        • ThinkGeo.MapSuite.Core.LogoAdornmentLayer
LogoAdornmentLayer()
  • This method is the default constructor for the LogoAdornmentLayer.
  • None
LogoAdornmentLayer(GeoImage)
  • This is the constructor for the LogoAdormentLayer that receives a specified logo.
  • image
    • Type:GeoImage
    • Description:This parameter represents the logo to be drawn on the map.
GetDrawingLocation(GeoCanvas,Single,Single)
  • adornmentWidth
    • Type:Single
  • adornmentHeight
    • Type:Single
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
  • This method draws the LogoAdornmentLayer.
  • This virtual method is called from the concreate public method Draw. In this method draw the representation of the layer based on the extent you provided. You can use the full power of the AdornmentLayer to do the drawing.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter are the labels used for collision detection and duplication check
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
OpenCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
Width
  • Type:Single
Height
  • Type:Single
BackgroundMask
Location
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
ActualWidth
  • Type:Single
IsOpenCore
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.logoadornmentlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
