thinkgeo.mapsuite.mapsuitegeocoder.simplifiedsoundex
ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex
This is the derived class from the Soundex class which implements a simplfied soundex algorithm.
    • ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex
      • ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex
SimplifiedSoundex()
  • This is the constructor of this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#SimplifiedSoundex.28.29
GenerateSoundex(String)
  • This is the override method to generate soundex code.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GenerateSoundex.28String.29
  • Description:The soundex code generated from the source text.
  • sourceText
    • Description:The source text to generate soundex.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetType.28.29
EncodeChar(Char)
  • This is the virtual method to encode char.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#EncodeChar.28Char.29
  • Description:Encoded char.
  • value
    • Type:Char
    • Description:Source char.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#MemberwiseClone.28.29
thinkgeo.mapsuite.mapsuitegeocoder.simplifiedsoundex.txt · Last modified: 2017/03/16 21:59 (external edit)
