thinkgeo.mapsuite.core.cogoinformation
ThinkGeo.MapSuite.Core.CogoInformation
    • ThinkGeo.MapSuite.Core.CogoInformation
CogoInformation()
CogoInformation(Double,PolygonShape,String,Double,Double,Double,PointShape,Feature,Int32,Boolean,PointShape,IEnumerable<Feature>)
  • areaInAcres
  • closureDirection
  • closureDistanceInFeet
  • closureRatio
  • distanceInFeet
  • pobFeature
  • segmentCount
  • isClosed
  • segments
    • Type:IEnumerable<Feature>
AreaInAcres
ClosedPolygon
ClosureDirection
ClosureDistanceInFeet
ClosureRatio
DistanceInFeet
EndPoint
IsClosed
PobLineFeature
SegmentCount
Segments
StartPoint
thinkgeo.mapsuite.core.cogoinformation.txt · Last modified: 2017/03/16 21:59 (external edit)
