thinkgeo.mapsuite.desktopedition.drawnoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn.
      • ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs
DrawnOverlayEventArgs()
  • This is the default constructor. If you use this constructor then you need to set the required properties manually.
DrawnOverlayEventArgs(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#DrawnOverlayEventArgs.28GeoCanvas.29
  • geoCanvas
    • Type:GeoCanvas
    • Description:This parameter is the GeoCanvas that have drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs#MemberwiseClone.28.29
GeoCanvas
  • This property gets and sets the GeoCanvas we are drawing on.
thinkgeo.mapsuite.desktopedition.drawnoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
