thinkgeo.mapsuite.core.tilematrixcell
ThinkGeo.MapSuite.Core.TileMatrixCell
    • System.ValueType
      • ThinkGeo.MapSuite.Core.TileMatrixCell
TileMatrixCell(Int64,Int64,RectangleShape)
  • This is the constructor used to create a TileMatrixCell.
  • None
  • row
    • Type:Int64
    • Description:This parameter represents the row number of the TileMatrixCell.
  • column
    • Type:Int64
    • Description:This parameter represents the column number of the TileMatrixCell.
  • boundingBox
    • Description:This parameter represents the boundingBox of the TileMatrixCell.
  • This method is an override of the ToString functionality.
  • None
  • This method is an override of the GetHashCode functionality.
  • None
  • This method is an override of the Equals functionality.
  • None
Row
This property gets or sets the Row number of the stucture.
  • Type:Int64
Column
This property gets or sets the Column number of the stucture.
  • Type:Int64
BoundingBox
This property gets or sets the BoundingBox of the stucture.
thinkgeo.mapsuite.core.tilematrixcell.txt · Last modified: 2017/03/16 21:59 (external edit)
