thinkgeo.mapsuite.core.tabdbfcolumn
ThinkGeo.MapSuite.Core.TabDbfColumn
    • ThinkGeo.MapSuite.Core.FeatureSourceColumn
      • ThinkGeo.MapSuite.Core.DbfColumn
        • ThinkGeo.MapSuite.Core.TabDbfColumn
TabDbfColumn()
  • This method is the constructor for the DbfColumn.
  • None
TabDbfColumn(String,DbfColumnType,Int32,Int32,Boolean,Boolean)
  • None
  • columnName
    • Description:This parameter represents the name of the column in the DBF.
  • columnType
    • Description:This parameter represents the type of the column in the DBF.
  • length
    • Description:This parameter represents the length of the column in the DBF.
  • decimalLength
    • Description:This parameter represents the number of decimal places the column has, if it is a numeric type.
  • buildIndex
  • uniqueIndexColumnValues
BuildIndex
This property returns the index of the column in the DBF.
UniqueIndexColumnValues
This property returns the value of the column in the DBF is unique or not.
ColumnType
Length
DecimalLength
ColumnName
TypeName
MaxLength
thinkgeo.mapsuite.core.tabdbfcolumn.txt · Last modified: 2017/03/16 21:59 (external edit)
