thinkgeo.mapsuite.core.requestingdatawfsfeaturesourceeventargs
ThinkGeo.MapSuite.Core.RequestingDataWfsFeatureSourceEventArgs
This class represents the parameters passed in through the RequestingData event in WfsFeatureSource.
      • ThinkGeo.MapSuite.Core.RequestingDataWfsFeatureSourceEventArgs
RequestingDataWfsFeatureSourceEventArgs()
  • This is a default constructor for the class.
  • None
RequestingDataWfsFeatureSourceEventArgs(String,Boolean,String)
  • None
  • serviceUrl
    • Description:This parameter specified the serviceUrl for the WfsFeatureSource.
  • overrideResponse
    • Description:This parameter specified if we need to override Response if we changed the response string.
  • xmlResponse
    • Description:This parameter specified the xmlResponse string get back from the service Url.
ServiceUrl
This property gets or sets the serviceUrl for the WfsFeatureSource.
OverrideResponse
This property gets or sets the override mode. If set it ture, we will replace the response with new XmlResponse String passed in.
XmlResponse
This property gets or sets the xml response string back from for the WfsFeatureSource service url.
thinkgeo.mapsuite.core.requestingdatawfsfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
