thinkgeo.mapsuite.core.executingsqlstatementmssql2008featuresourceeventargs
ThinkGeo.MapSuite.Core.ExecutingSqlStatementMsSql2008FeatureSourceEventArgs
This class represents the parameters passed in through the ExecutingSqlStatement event in MsSql2008FeatureSource.
      • ThinkGeo.MapSuite.Core.ExecutingSqlStatementMsSql2008FeatureSourceEventArgs
ExecutingSqlStatementMsSql2008FeatureSourceEventArgs(String)
  • None
  • sqlStatement
    • Description:This parameter is the sqlStatement that will be passed in to excute.
ExecutingSqlStatementMsSql2008FeatureSourceEventArgs(String,ExecutingSqlStatementType)
  • None
  • sqlStatement
  • sqlStatementType
SqlStatement
This property gets and sets the SqlStatement that will be excuted.
This property gets and sets the SqlStatementType of the SqlStatement that will be excuted.
thinkgeo.mapsuite.core.executingsqlstatementmssql2008featuresourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
