TiledWmsLayer(IEnumerable<Uri>,String,String)
TiledWmsLayer(IEnumerable<Uri>,WebProxy,String,String)
GetFeatureInfo(ScreenPointF,Int32)
GetFeatureInfo(ScreenPointF,String,Int32)
GetRequestUrisCore(RectangleShape,Int32,Int32)
GetFeatureInfoCore(ScreenPointF,String,Int32)
Contains(RectangleShape,RectangleShape)
This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
Gets or sets a value that is unique to your client ID, please keep your key secure.
This property gets or sets the proxy used for requesting a Web Response.
This property gets or sets the desired output format for the map requested from the WMS.
When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
This property gets or sets the projected or geographic coordinate reference system to be used.
Is the current scale is beyond this value, the map will not render.
Is the current scale is less than this value, the map will not render.
This property represents the available layers that can be requested from the client and shown on the map.
When requesting a map, a client may specify the layers to be shown on the map.
This property represents the available styles that can be requested from the client and shown on the map.
When requesting a map, a client may specify the styles to be shown on the map.
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
This property indicates the format in which the client wishes to be notified of service exceptions.
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
This property specifies a dictionary used to update the request sent from the client to the WMS server.
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The value of TileWmsLayer is false.
Various methods on the Layer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the Layer Open method. The method will raise an exception if the current Layer is already open.
