thinkgeo.mapsuite.core.geoserializationformatter
ThinkGeo.MapSuite.Core.GeoSerializationFormatter
This class formats a GeoObjectModel into serialized data.
GeoSerializationFormatter()
  • Creates an instance of GeoSerializationFormatter.
Save(GeoObjectModel,Stream)
  • Save serialized data into a stream.
  • model
    • Description:The GeoObjectModel to create serialized data for.
  • stream
    • Type:Stream
    • Description:The Stream to save serialized data into.
Load(Stream)
  • Load a stream into a GeoObjectModel.
  • Description:The GeoObjectModel recreated from the stream.
  • stream
    • Type:Stream
    • Description:The Stream to load from.
SaveCore(GeoObjectModel,Stream)
  • Format a GeoObjectModel into serialized data, and save the data into a stream.
  • model
  • stream
    • Type:Stream
LoadCore(Stream)
  • stream
    • Type:Stream
Encoding
set or get the readEncoding.
  • Type:Encoding
thinkgeo.mapsuite.core.geoserializationformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
