thinkgeo.mapsuite.core.xmlgeoserializationformatter
ThinkGeo.MapSuite.Core.XmlGeoSerializationFormatter
This class formats a GeoObjectModel into XML.
    • ThinkGeo.MapSuite.Core.GeoSerializationFormatter
      • ThinkGeo.MapSuite.Core.XmlGeoSerializationFormatter
XmlGeoSerializationFormatter()
  • Creates an instance of GeoSerializationFormatter.
Save(GeoObjectModel,Stream)
  • stream
    • Type:Stream
Load(Stream)
  • stream
    • Type:Stream
SaveCore(GeoObjectModel,Stream)
  • Format a GeoObjectModel into XML, and save the XML into a stream.
  • model
    • Description:The GeoObjectModel to create XML for.
  • stream
    • Type:Stream
    • Description:The Stream to save XML into.
LoadCore(Stream)
  • Load a stream that contains XML into a GeoObjectModel.
  • Description:The GeoObjectModel recreated from the stream.
  • stream
    • Type:Stream
    • Description:The Stream that contains XML.
Encoding
  • Type:Encoding
thinkgeo.mapsuite.core.xmlgeoserializationformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
