thinkgeo.mapsuite.iosedition.mapdoubletapmode
ThinkGeo.MapSuite.iOSEdition.MapDoubleTapMode
This enumeration specifies the behavior that occurs when double tap on the MapControl. The default value is ZoomIn.
Items
Default
  • Summary:Default value (ZoomIn) of the enumeration.
ZoomIn
  • Summary:This enumeration item means that the map will ZoomIn when a double tap occurs.
Disabled
  • Summary:This enumeration item means that the ZoomIn functionality for double tap will be disabled.
thinkgeo.mapsuite.iosedition.mapdoubletapmode.txt · Last modified: 2017/03/16 21:59 (external edit)
