thinkgeo.mapsuite.webedition.maptools
ThinkGeo.MapSuite.WebEdition.MapTools
Contains the different map tools as properties and acts as an entrance for setting these map controls.
    • ThinkGeo.MapSuite.WebEdition.MapTools
MapTools()
  • Initialize an instance of the MapTools class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MapTools.28.29
ToJson()
  • Returns a JSON string that contains all of the map tools settings.
  • This method is used to generate the JSON string for all of the map controls. The JSON string will be sent to the client side to create corresponding client-side map controls.
  • Description:A JSON string that represents the settings for all of the map tools.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MemberwiseClone.28.29
MeasureMapTool
Gets an MeasureMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MeasureMapTool
TouchMapTool
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#TouchMapTool
AnimationPanMapTool
Gets an AnimationPanMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#AnimationPanMapTool
OverlaySwitcher
Gets an OverlaySwitcherMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#OverlaySwitcher
MouseMapTool
Gets a MouseMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseMapTool
MouseCoordinate
Gets a MouseCoordinateMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseCoordinate
MiniMap
Gets a MiniMapMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MiniMap
PanZoom
Gets a PanZoomMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoom
PanZoomBar
Gets a PanZoomBarMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoomBar
ScaleLine
Gets a ScaleLineMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ScaleLine
Logo
Gets a LogoMapTool object for setting
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Logo
KeyboardMapTool
Gets a KeyboardMapTool object for setting.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#KeyboardMapTool
LoadingImage
Gets a LoadingImageMapTool object for setting
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#LoadingImage
thinkgeo.mapsuite.webedition.maptools.txt · Last modified: 2017/03/16 21:59 (external edit)
