thinkgeo.mapsuite.webedition.overlayswitchermaptool
ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool
Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool
OverlaySwitcherMapTool()
  • Initialize an instance of OverlaySwitcherMapTool class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#OverlaySwitcherMapTool.28.29
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#MemberwiseClone.28.29
OnClientBaseOverlayChanged
Gets or sets the client-side script that executes after the base overlay changes in the OverlaySwitcher.
The Javascript that is set to this property will be injected into the page and executed whenever the BaseOverlayChanged event occurs at the client side.
RoundedCornerColor
Gets or sets the rounded corner color of the OverlaySwitcher object.
BackgroundColor
Gets or sets the background color of the OverlaySwitcher object.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#BackgroundColor
BaseOverlayTitle
Gets or sets the base overlay part title of OverlaySwitcher panel
DynamicOverlayTitle
Gets or sets the dynamic overlay part title of OverlaySwitcher panel
Enabled
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool#Enabled
thinkgeo.mapsuite.webedition.overlayswitchermaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
