thinkgeo.mapsuite.webedition.measuremaptool
ThinkGeo.MapSuite.WebEdition.MeasureMapTool
Represents the measure map tool which allows measurements for features.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.MeasureMapTool
MeasureMapTool()
  • Initialize an instance of the MeasureMapTool class.
  • The default MeasureType is Line, and the display system units is Metric by default, also it measures geodesic distance by default.
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MemberwiseClone.28.29
MeasureType
Represents the different types of the MeasureMapTool.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureType
MeasureUnitType
Represents the display system units for output measurements.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureUnitType
Geodesic
Indicate whether to measure geodesic distance.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Geodesic
Enabled
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Enabled
thinkgeo.mapsuite.webedition.measuremaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
