thinkgeo.mapsuite.webedition.animationpanmaptool
ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool
AnimationPanMapTool()
  • Initialize an instance of the AnimationPanMapTool class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#AnimationPanMapTool.28.29
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#MemberwiseClone.28.29
Delay
The number of milliseconds between clicks before the event is considered a double-click.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#Delay
OnClientClick
Gets or sets the client-side script that executes when you click on the map using this Animation Pan map tool.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#OnClientClick
Enabled
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#Enabled
thinkgeo.mapsuite.webedition.animationpanmaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
