thinkgeo.mapsuite.webedition.panzoommaptool
ThinkGeo.MapSuite.WebEdition.PanZoomMapTool
Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
    • ThinkGeo.MapSuite.WebEdition.MapTool
      • ThinkGeo.MapSuite.WebEdition.PanZoomMapTool
PanZoomMapTool()
  • Initialize an instance of the PanZoomMapTool class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#PanZoomMapTool.28.29
ToJson()
  • Returns a JSON string that represents the map control object.
  • This method returns a JSON string that instructs the client Javascript to create a specific client object.
  • Description:A JSON string that represents the map control.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#MemberwiseClone.28.29
IsGlobeButtonEnabled
Gets or sets a boolean value that determines whether the globe button shows in the PanZoom map tool.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#IsGlobeButtonEnabled
Enabled
Gets or sets a value that turns the feature on and off.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.PanZoomMapTool#Enabled
thinkgeo.mapsuite.webedition.panzoommaptool.txt · Last modified: 2017/03/16 21:59 (external edit)
