thinkgeo.mapsuite.core.geohatchbrush
ThinkGeo.MapSuite.Core.GeoHatchBrush
This class represents a brush that fills with various patterns.
    • ThinkGeo.MapSuite.Core.GeoBrush
      • ThinkGeo.MapSuite.Core.GeoHatchBrush
GeoHatchBrush(GeoHatchStyle,GeoColor)
  • This is the constructor for the class.
  • You will use this constructor when you want to only specify the foreground color of the pattern and leave the background transparent.
  • hatchStyle
    • Description:This property is the hatch pattern you want to use to fill the area.
  • foregroundColor
    • Type:GeoColor
    • Description:This property is the foreground color you want to use for the pattern.
GeoHatchBrush(GeoHatchStyle,GeoColor,GeoColor)
  • This constructor allows you to choose both the background and foreground color for the pattern.
  • hatchStyle
  • foregroundColor
    • Type:GeoColor
  • backgroundColor
    • Type:GeoColor
    • Description:This property is the background color you want to use for the pattern.
CloneDeep()
CloneDeepCore()
HatchStyle
This property gets and sets the pattern you want to use for the fill.
ForegroundColor
This property gets and sets the foreground color for the fill pattern.
In this case the background color will be transparent.
BackgroundColor
This property gets and sets the background color for the fill pattern.
In this case the foreground color will be transparent.
Id
  • Type:Int64
thinkgeo.mapsuite.core.geohatchbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
