thinkgeo.mapsuite.core.filenativeimagetilecache
ThinkGeo.MapSuite.Core.FileNativeImageTileCache
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.NativeImageTileCache
        • ThinkGeo.MapSuite.Core.FileNativeImageTileCache
FileNativeImageTileCache()
  • This is the default constructor.
  • If you use this constructor, you have to set the properties manually.
FileNativeImageTileCache(String,String,TileImageFormat,TileMatrix)
  • This is the constructor with all the parameters needed passed in.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
  • This method returns the NativeImageTile corresponding to passed in row and column.
  • Description:Returns the NativeImageTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
SaveTileCore(Tile)
  • This method will save the target tile passed in, you could override this API to create your own logic.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
  • This method will delete the target tile passed in.
  • This method will not take effect when the ReadOnly is set to true.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
ClearCacheCore()
  • This method will clear all the tiles in the tileCache.
CacheDirectory
Gets or sets the cache direcory.
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
thinkgeo.mapsuite.core.filenativeimagetilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
