thinkgeo.mapsuite.core.creatingmembernodegeoobjectmodelereventargs
ThinkGeo.MapSuite.Core.CreatingMemberNodeGeoObjectModelerEventArgs
      • ThinkGeo.MapSuite.Core.CreatingMemberNodeGeoObjectModelerEventArgs
CreatingMemberNodeGeoObjectModelerEventArgs()
  • Creates an instance of CreatingMemberNodeGeoObjectModelerEventArgs.
CreatingMemberNodeGeoObjectModelerEventArgs(String,Object,Type,Object)
  • Creates an instance of CreatingMemberNodeGeoObjectModelerEventArgs with name, value, type and owner.
  • name
    • Description:The name of the member.
  • value
    • Description:The value of the member.
  • type
    • Description:The type of the member.
  • owner
    • Description:The owner of the member.
Gets or sets the name of the member.
Value
Gets or sets the value of the member.
Type
Gets or sets the type of the member.
Owner
Gets or sets the owner of the member.
thinkgeo.mapsuite.core.creatingmembernodegeoobjectmodelereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
