thinkgeo.mapsuite.windowsphonecore.drawingrectanglef
ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF
<!– Structure –> This structure represents the drawing of a rectangle in screen coordinates.
Public MethodDrawingRectangleF Double, Double, Double, Double This method represents the constructor that should be used to create the structure.
Public MethodEquals Object Object(overriden) This method is an override of the Equals functionality.
Public MethodGetHashCode Object(overriden) This method is an override of the GetHashCode functionality.
Public MethodGetType Object
Public MethodToString Object(overriden)
Public PropertyCenterX Double This parameter represents the center horizontal value of the rectangle.
Public PropertyCenterY Double This parameter represents the center vertical value of the rectangle.
Public PropertyHeight Double This parameter returns the height of the rectangle.
Public PropertyWidth Double This parameter returns the width of the rectangle.
DrawingRectangleF(Double, Double, Double, Double)
Name Type Description
centerX Double<!– System.Double –> This parameter represents the center horizontal value of the rectangle.
centerY Double<!– System.Double –> This parameter represents the center vertical value of the rectangle.
width Double<!– System.Double –> This parameter represents the width of the rectangle.
height Double<!– System.Double –> This parameter represents the height of the rectangle.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
CenterX
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –> Go Back
CenterY
Return Type
Height
Return Type
Width
Return Type
thinkgeo.mapsuite.windowsphonecore.drawingrectanglef.txt · Last modified: 2017/03/16 21:59 (external edit)
