thinkgeo.mapsuite.core.ecwrasterlayer
ThinkGeo.MapSuite.Core.EcwRasterLayer
This class represents an ECW image to be drawn on the map.
EcwRasterLayer()
  • If you use this constructor, then you need to set the PathFileName property manually before using the layer.
EcwRasterLayer(String)
  • This constructor gets the layer ready to use.
  • imagePathFilename
    • Description:This parameter is the path and filename of the ECW file you want to use.
EcwRasterLayer(String,String)
  • imagePathFilename
  • worldfilePathFilename
    • Description:This parameter is the world file path and filename for the ECW file you want to use.
EcwRasterLayer(String,RectangleShape)
  • imagePathFilename
  • imageExtent
    • Description:This parameter is the image extent of ECW file you want to use.
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In EcwRasterLayer, we override this API and mark it as true.
PathFilename
This property gets and sets the path and filename of the ECW file you want to use.
This should be the complete path and filename for an ECW file.
ImageSource
WrappingMode
WrappingExtent
UpperThreshold
LowerThreshold
HasProjectionText
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.ecwrasterlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
