thinkgeo.mapsuite.core.csharpgeocodeformatter
ThinkGeo.MapSuite.Core.CSharpGeoCodeFormatter
This class formats a GeoObjectModel into C# code.
    • ThinkGeo.MapSuite.Core.GeoCodeFormatter
      • ThinkGeo.MapSuite.Core.CSharpGeoCodeFormatter
CSharpGeoCodeFormatter()
  • Creates an instance of CSharpGeoCodeFormatter.
Save(GeoObjectModel,Stream)
  • stream
    • Type:Stream
SaveCore(GeoObjectModel,Stream)
  • Creates C# code for a GeoObjectModel and save the code into a Stream.
  • model
    • Description:The GeoObjectModel to generate C# code for.
  • stream
    • Type:Stream
    • Description:The Stream to save C# code into.
thinkgeo.mapsuite.core.csharpgeocodeformatter.txt · Last modified: 2017/03/16 21:59 (external edit)
